Paints6-1
3-coat Pearl (White Pearl) Paint6-11 |
Coating Procedures
Refer to page 6-5 , page 6-6 , page 6-7 and page 6-8 for the previous procedures from the intermediate coat.
- Spraying color base.
- Spray the color-matched color base over the surface until the primer surface is fully covered.
- Use the acrylic urethane color base.
- On pearl paint: the color of the color base will determine the final color of the paint repair.
- Drying
- After spraying color base, allow for 5 to 10 minutes of normal drying time, then force dry it with infrared lamps or other industrial dryer.
- NOTE: Follow the color base manufacturer's instruction for drying time.
- Polishing
- Check that the color base has dried thoroughly, then dry or wet sand the color base.
Use the flexible block and #600, #800, #1000 sandpapers.
- NOTE: Be careful not to polish down to the primer surfacer.
- When the painting repair (gradation) is almost done, polish the area that will be top coated.
Use the #2000 sandpaper and compound.
- Air blowing / degreasing
Use alcohol, wax, and grease remover.
- Also clean and degrease the surfaces where the masking tape will be attached.
- Masking
- Remove all existing masking tape, then mask with new ones.
- Mask the area surrounding the damage sufficiently to prevent overspray. It is also a good practice to use a vinyl cover to protect other areas.
- Use a heat-resistant masking tape where it is attached directly to body.
- Use brown paper or masking roll paper.
- NOTE: Protect the plastic parts with aluminum foil under the brown paper or masking paper to prevent damage to due to heat during baking.
- Air blowing
- Thoroughly clean the interior, and spray water over the floor. Be careful about blowing dust and dirt.
Use the alcohol, wax, and tack cloth.
- Spraying color base/pearl base/clear coat spray the color-matched color base over the prepared surface.
Use the acrylic urethane color base and a spray gun.
- Spray the color-matched pearl base 2~3 double coat over the surface until the color base is fully covered.
Use the acrylic urethane pearl base and a spray gun.
- Spraying clear coat
- Spray the top coat clear evenly over the surface of the pearl base. Do not try to cover the surface with one heavy coat.
- Drying
- After spraying the clear coat, allow it to dry for 10 minutes, then force dry it with infrared lamps or other industrial dryer.
- NOTE: Follow the paint manufacturer's instructions for drying times.
3-coat Pearl (White Pearl) Paint (cont'd)6-12
Coating Procedures (cont'd)
- Polishing / buffing
- Check the clear coat has dried thoroughly.
- The clear coat is cooled.
- Any adhesion or roughness on the top coat Should be wet sand and repaired.
Use the #2000 and crystal block.
- Polish all roughness caused by sanding.
- NOTE : Clear the top coat surface frequently so you don't damage the clear coat with the polishing particles.
Use a buffing towel, buffing wool, and compound.
- Finishes up with buffing.
- NOTE:
- Do not use a power buffer.
- Don't polish too much; use light hand pressure.
Use the buffing sponge, fine compound, very fine compound, then Wtra fine compound
- After buffing, remove the masking paper and tape, and thoroughly wash the entire vehicle.
Painting Repair (Gradation)6-12
Repair of 3-coat pearl paint coat requires different procedure from that of metallic paint coats.
Determination of color:
- Sand the damaged paint coat until the intermediate coat appears.
- Polish the exposed paint coat, then compare is color with the color sample provided.
- Prepare a paint based on the color sample selected according to the instructions.
- After preparing, check that the paint prepared matches the color sample selected in step 2 above.
- NOTE : On pearl paint, the color of the intermediate coat will determine the final color of the paint repair.
6-13
Mixing (Reference):
The prepared paint should be mixed with thinner and hardner as follows.
Following example: 2-part polyester urethane paint
PAINT
(Color base)
Thinner with hardner function 100 ~ 130 % Prepared paint 100
PAINT
(Pearl base)
Thinner with hardner function 100 ~ 130 % Top coat (pearl base) 100
The above paints and materials or their equivalents should be used.
NOTE: Follow the paint manufacturer's instructions when mixing the paint and other materials.
Refinishing procedures:
- To prepare the first coat (paint
) add a 1 part of paint
to 1 part of paint
and stir well.
- Pour the mixture through a filter, then spray 2-3 light coats over the damaged surface.
- NOTE: Spray the mixture until the intermediate coat is thoroughly covered.
- Prepare paint
for gradation by mixing 1 part of paint
with 19 parts of the paint
. Stir the mixture well.
- Pour the mixture through a filter, then spray 2-3 light coats the filtered mixture over paint
, starting at the center, then working toward the edge.
- NOTE:
- Check that the painted coat matches the color of the body paint while spraying.
- Application of the mixture will determine the final color of the paint repair. Do not spray the mixture excessively as this may alter the final color of the repair.
3-coat Pearl (White Pearl) Paint (cont'd)6-14
Painting Repair (Gradation) (cont'd)
- Prepare paint
of top coat by mixing 1 part of the pearl base with 1 part of the paint
- Apply 1-2 light coats of paint
over the repaired surface.
- For the final top coat, add 0 ~ 20% thinner to a 5 : 1 mixture of the clear paint and hardener.
- Spray 2-3 light final top coats over the damaged area.
- Apply the clear coat gradation around the final top coat.
Paints6-1
